missing lynx wrote:has your green wire come out the cdi or wire block in the head set?
mr series 2 wrote:I had exactly the same problem a couple of weeks ago
Turned out the earth wire from the ignition switch was not earthing properly
Hope this helps
davla wrote:missing lynx wrote:has your green wire come out the cdi or wire block in the head set?
I checked this today, the green wire is connected fine....when i disconnect it however the engine dies. I need to check a wiring diagram...
coaster wrote:davla wrote:missing lynx wrote:has your green wire come out the cdi or wire block in the head set?
There should be TWO green wires in the CDI, one comes up from the stator and the other goes into the main loom and runs up to the ignition switch. When you turn the key to the off position it connects through to earth thus shorting the ignition.
davla wrote:Sorted, I checked my wiring and found a rogue wire disconnected that was also connected to the regulator and the loom, presumably going to the headset. Connected it to the CDI and ignition barrel works as it should, thanks for your help.
