Adam_Winstone wrote:I once helped a mate with a rebuild and we checked the ring gap in the bore and also piston skirt to bore, part way up the bore, and they were both 100% right. However, he repeatedly nipped up and I thought it was down to his inability to control his wrist whilst running in, as timing, jetting, compression, fuel flow, etc. were all fine. In the end I stripped it again to check and found that the piston was still fine in the bore, however, I then went to push the piston out of the top of the barrel and it locked up on the skirt! Turns out that the rebore was off line and conical!!!! Done by an a many decade established UK dealer.
As we didn't have time to send it back, a 3-leg hone was used to increase clearance at the top of bore, not much we could do about slight alignment issue. This barrel then ran faultlessly 2-up to Milan and back in 97.
Fast n Furious wrote:Are the piston rings fitted?
