I have a Pacemaker gear set with the early hollow cluster and the later 3rd gear cog.
Can these be used together? I'm guessing not.
AlG wrote:I have used both, and had a late cluster centre drilled to take a pressure plate with the central locating pin. Always the strong 3rd and typically run 18x47 for 4.8 final drive.
Warkton Tornado No.1 wrote:I use a hollow cluster in a Rapido 245 which pulls 19 x 46 (same as TV200, so quite grunty) with a third with the stronger teeth (33.8 mm across five teeth)
Users browsing this forum: Baidu [Spider] and 118 guests
