Fast n Furious wrote:Cast and forged pistons have different coefficients of expansion.
The problem is in obtaining this information so you can make an informed decision as to what your bore clearance should be.
Forged pistons are not really better. They just have different problem properties compared to cast.
If there was any worthy advantage to using Forged, the Japs would have used them in their 2 strokes and the mass production cost difference between cast and forged would be negligible to these big boys.
Kawasaki did use Forged in their early 2 strokes but even they gave up using them by the mid 1980's.
IMO. the forged, with proper bore clearance in a properly cooled cylinder will stand the stresses for longer.
I usually change pistons because the skirts start to crack away around the pin, which is normal in a tuned cylinder with a cast piston. The trick of course is being able to catch it before it breaks off!
jonno wrote:That is what I cant understand,the CR piston didnt cause wear like the new one.Only needed a touch up after 2 seasons of sprinting.
a-teamlambretta wrote:too many holes ?? expansion and contraction of steel liner ?? , rings clattering over the holes ect ??
jonno wrote:The wiseco seems right as a replacement so presumably the rings are right too.The rings edges arent smooth now.Seems like the rings are too hard ?
Warkton Tornado No.1 wrote:Personally, I like Wiseco despite the fact that they are forged (as opposed to Top Tuners preference in cast) but doubt that would be the problem, though what bore clearance did your borer set? Too tight or too slack can exasperate wear. Ring gap is another factor that needs consideration.
Presumably your machinist has made the bore absolutely perpendicular to the deck....
Wiseco also have alternate rings for most of its piston sizes to suit different bore materials. You should be running rings to suit cast iron. The full catalogue is easily accessible on line.
I’d doubt that the oil is a problem as Rock Synthesis is good @ 33:1 (as I can vouch) but I have been amazed @ the quality of Exol Optima @ 50:1 after I tentatively started using it in a non-race tuned engine. How many Manufacturers produce non-castor based two stroke oils specifically for air-cooled race engines?
Fast n Furious wrote:I'd feel lot happier with 0.05mm of bore clearance and 0.1mm of ring gap.
jonno wrote:There is a code on the piston box of 2276CD.Which I'm guessing is the ring part number.The bag for the piston rings has a code 2520CD.I'm guessing the difference is for nicasil and iron ?
