leebo1974 wrote:Hi all, I'm new to the forums,
question regards jetting etc, having just rebuilt my 1965 TV175 motor using a RT195 top end and numerous other expensive parts, I've also added a Dellorto PHBH 30mm carb & having difficulties jetting/tuning it in.
Current setting are:
Main jet 125
Pilot 55
Atomiser 264
Slide 40
Needle X7
Needle position second from the bottom,
The bike starts and ticks over not too bad but giving it a little run down street is awful very intermittent/boggy
Any suggestions appreciated.
leebo1974 wrote:
I know I'm probably going to have to take to a dyno
Why would you do that? I did that once and all it did was tell me how much power the thing was making, once back home I had to set it up myself as it was running like a bag of shite and dangerously lean. Setting up on a dyno is one thing but we ride on the road so set it up on the road, takes longer but better in the long term.
Change to a AV266 atomiser, 55 pilot x7 needle and have a play around with a half step washer and see how it goes.
(Bet that's raised a few pulses!).
Meds wrote:I had exactly the same issues
have a look at this
http://scooterotica.org/forum/viewtopic.php?f=9&t=36233
Paul
bluebob wrote:please take note of the guys advising you to up the atomiser to av 266
holty wrote:i a sure you have checked, but make sure your choke is off fully, if not it will run very rich, i always make sure i have a bit of free play on the cable when switched off.
leebo1974 wrote:bluebob wrote:please take note of the guys advising you to up the atomiser to av 266
I've ordered a 266 to try.
Scooterdude wrote:When ordering Delortto jets etc I've found Wasp performance beats everyone else hands down.
Toddy wrote:Scooterdude wrote:When ordering Delortto jets etc I've found Wasp performance beats everyone else hands down.
+1
