Series 3 legshield question
Postby LuiLui » Tue Sep 12, 2017 7:47 pm
Evening all,
Just dropped bodywork off at painters for a respray and remembered that tip about the lip on the rear of the legshields (under the bridge piece). They're new legshields so the lip is still at 90 degrees.
Question is: is it just the top needs folding under, or all three sides? I read if you don't do it there's a possibility it digs into the wiring.
Marki
LuiLui
Re: Series 3 legshield question
Postby Fast n Furious » Wed Sep 13, 2017 12:23 am
If the wiring loom is routed and secured correctly then usually there is no need.
If it is a touch close then just fettle it in that area.
Postby LuiLui » Thu Sep 14, 2017 6:31 pm
Many thanks, I'll stand down on the emergency dash to go and sort them out before he starts spraying.
Mark
LuiLui
Users browsing this forum: No registered users and 76 guests
