Help with an oil seal spring?
Postby davla » Tue Sep 12, 2017 3:09 pm
I'm rebuilding my engine and have slightly damaged the spring on the inner oil seal on the mag housing so it's got a slight kink in it (I would upload pics but I can't work out how since Photobucket have gone into a sulk) I'm tempted to put it back together as it is but I'm guessing advise would be 'don't risk it' and use another spring. Unfortunately I don't have another seal knocking around and don't really need to order anything at the moment so was wondering if anyone had a spring that I could have pls?
davla
Re: Help with an oil seal spring?
Postby Warkton Tornado No.1 » Tue Sep 12, 2017 4:38 pm
If the spring cannot be have it's kink removed (occasionally, then can be with pin nose pliers) I may have a spare you can have.
The springs vary dependent on manufacturer (Rolf is common) but I do have various. Call me mean ;) but I keep old seals just for the reason you have experienced!
What is the make (& size, just as a check) of the seal, & preferably the cross section diameter of the spring (probably less than Ø3 mm), please?
Postby davla » Tue Sep 12, 2017 4:59 pm
Great, thanks, It's a brown viton seal, not sure of make as it's now installed but it came from AF. I'll check dimensions when I get home.
davla
Postby davla » Wed Sep 13, 2017 11:21 am
The spring diameter is 1.5mm
davla
