Standard 150 kit
Standard 150 kit
Postby Geocamper » Sat Sep 09, 2017 12:14 pm
I'm looking for recommendations for the best quality barrel,Piston and cylinder head kit for a Li150. Doing a full rebuild and I would like to keep to standard.
Geocamper
Re: Standard 150 kit
Postby holty » Sat Sep 09, 2017 12:34 pm
gori do some realy nice cast barrel kits in 175 and 200 to fit the 150 case, my pal has a 175 and they are very high quality, nothing like the cheap indian rubbish out there.
holty
Postby Geocamper » Sat Sep 09, 2017 12:47 pm
Cheers Holty.
As a complete novice at a rebuild and kits, Would I be able to put a 175 top end on a standard build 150 gearbox? I don't want to change the gearing or anything inside the casing from a 150?
Geocamper
Postby dickie » Sat Sep 09, 2017 1:45 pm
Geocamper wrote:Cheers Holty.
Yes, absolutely. The carb will need to be adjusted slightly to suit, but that's neither hither nor thither.
