series 2breakdown
series 2breakdown
Postby JBG584 » Tue Aug 29, 2017 12:08 am
Just back from IOW rally on my series 2 original engine. Had a few problems same thing each time after about 5 miles she just stops, actually it happened 4 times not seized as still kicked over but wouldn't start put in new plug started went then 5 miles approx stopped again some lads even tried bumping no go waited 10 minutes or so started first time then approx 5 miles stopped.I think it got just to hot have you or any of the lads got any ideas
JBG584
Re: series 2breakdown
Postby Warkton Tornado No.1 » Tue Aug 29, 2017 1:27 am
Electrical (or electronic) components don’t really fare very well, mounted as they are in the case of the stator, subject to heat & vibration.
For my sins :roll: I persevere with points ignition even on a tuned engine in my current ride, which let me down recently. It was running great, & then wouldn’t start after a brief thrash.
I suspected the condenser which it proved to be. So, if I was a betting man....
I doubt you’ll find cheaper, or better, than AF Rayspeed ;)
Postby lammydave » Tue Aug 29, 2017 4:42 am
could be coil knackered or fuel cap breather blocked
lammydave
Postby stephena » Tue Aug 29, 2017 7:52 am
I had the same problem a few weeks ago turned out to be faulty stator sent off to Anthony Tambs all ok now.
stephena
Postby Rich Oswald » Tue Aug 29, 2017 11:11 am
Air scoop blocked or filler breather blocked?
Postby Fast n Furious » Tue Aug 29, 2017 11:17 am
Assuming that there was no spark and the ignition is points, then I agree with WT1. Most likely the condenser, which can go short circuit when they are old and hot. My mate has a 650Z quacker which does the same thing.
Postby JBG584 » Tue Aug 29, 2017 12:54 pm
Hi checked spark it was fine bright even in the sunlight
JBG584
Postby Warkton Tornado No.1 » Tue Aug 29, 2017 2:52 pm
JBG584 wrote:Hi checked spark it was fine bright even in the sunlight
When the condenser fails, you will most likely still get a spark! They rarely fail 'open circuit'. That fools any of us into believing it can't be the problem. They can be fine one minute & bad the next & those intermittent faults are the worst!
When my condenser went recently, there was still a spark with the plug out, & my Mate said it couldn't be ignition, but I've been 'there' too many times now..... :roll:
Postby JBG584 » Tue Aug 29, 2017 5:27 pm
Hi
will try that cheers
JBG584
Postby JBG584 » Sun Jun 03, 2018 2:44 pm
Hi changed condenser and new plug and points took her out for the first time in a while still exactly the same just dies out after 5-8 miles have to wait 15 min and she will go fine
JBG584
Postby Digger » Sun Jun 03, 2018 4:59 pm
Petrol cap breather?
Digger
Postby Bogie » Sun Jun 03, 2018 6:49 pm
sounds like the coil is breaking down when hot , my series 1 was a pig for that until i found another filso coil
Bogie
Postby JBG584 » Sun Jun 03, 2018 10:10 pm
cheers for help
JBG584
Postby Scooterslag » Sun Jun 03, 2018 10:25 pm
Bogie wrote:sounds like the coil is breaking down when hot , my series 1 was a pig for that until i found another filso coil
Yep second on that- had a old V100 sport smallframe which used to do the same
Users browsing this forum: Baidu [Spider] and 48 guests
