D125 lights switch acts as cutout!
Postby Bettagetabrettabolti » Mon Aug 18, 2014 5:36 am
More help required chaps.
On my D 125 main headlight comes on fine when riding along the road but if I put them on when stationary acts like a cutout!
Any clues people?
Bolti
Re: D125 lights switch acts as cutout!
Postby Rob Miller » Mon Aug 18, 2014 7:56 am
Possibly needs the flywheel re-magnetising.
Rob Miller
Postby petemaisey » Mon Aug 18, 2014 5:51 pm
and a new condenser.
Pete
petemaisey
Postby Bettagetabrettabolti » Wed Aug 20, 2014 5:23 am
Both of these have been done so pretty baffled!
Thanks will continue to search!
Postby jbcollier » Sun Aug 24, 2014 2:32 pm
As you can see here:
http://s250.photobucket.com/user/jbcoll ... sort=3&o=0
The early ignition system is completely separate from the lighting system except at two points: green kill and ground.
First, disconnect the green wire at the engine and try switching on the lights at idle again. If that solves the problem, check to see if the switch is wired correctly, or if there is a problem in the switch itself. If the harness is very old check for the usual shorts from wire to wire.
If isolating the green kill wire doesn't solve the problem, then check your grounds! The engine has to be grounded to the frame or you will get ground circuit feedback issues.
jbcollier
Postby Bettagetabrettabolti » Thu Aug 28, 2014 8:51 am
Thanks for that JB - can you tell me where to ground it please.
Ta Bolti
Postby jbcollier » Thu Aug 28, 2014 2:12 pm
Dunno where the ground wire is located on a 125D as I have a 150D. Perhaps another list member who owns one will chime in.
jbcollier
Return to Pre 57
Users browsing this forum: Baidu [Spider] and 23 guests
