Warkton Tornado No.1 wrote:I’ve read this thread & would advise you not to get too tied up with what is an ideal pressure. You are in the right ball park & a leak down test is more relevant IMHO.
I’d look toward the head volume as advised. Personally, I’ve witnessed the effect of too high a compression ration with a track engine & it is incredible how it can stifle top ends & over-rev be non-existent.
Whilst I’m on my high horseI went back to just working on the geometric compression ratio some time ago as Bell says that if the expansion chamber/exhaust is doing its job, it will be returning pressure so precisely how can anybody state the full factors involved to apply in any ‘corrected’ calculations? Geometric compression is also easier to calculate!
Scooterdude wrote:Right I've stripped and checked the one I've been doing, firstly I did a compression test and found it was making bang on 150psi. The cylinder it's a standard 175 cheap cast iron one. I've measured the combustion chamber of the head and found it to be 20cc or 20ml.
kclewis wrote:OK I have stripped mine and the combustion chamber is 14cc and the head capacity including the squish band is 26.5 cc.
Keith
Warkton Tornado No.1 wrote:Scooterdude wrote:Right I've stripped and checked the one I've been doing, firstly I did a compression test and found it was making bang on 150psi. The cylinder it's a standard 175 cheap cast iron one. I've measured the combustion chamber of the head and found it to be 20cc or 20ml.
Worst case scenario as far as CR (Compression Ratio) is 1 mm squish (but best for piston crown cooling)
Therefore, CR = {[bore² x pi x (stroke + squish) ÷ 4] + head volume} ÷ head volume: 1
= {[6.2² x pi x (5.9)] ÷ 4] + 20} ÷ 20: 1
= 9.91: 1
(Please check my maths!)kclewis wrote:OK I have stripped mine and the combustion chamber is 14cc and the head capacity including the squish band is 26.5 cc.
Keith
Gulp! Are you sure? What squish is that?
kclewis wrote:Just refitted the head and with the piston at TDC it took 20CC to reach the bottom of the spark plug threads. Keith
= 9.91: 1
Keith
kclewis wrote:Thanks that's great, do you think you could measure the combustion chamber etc?
Cheers Keith.
Users browsing this forum: No registered users and 112 guests
