kclewis wrote:Just done a compression test on the motor and it came out at 8 Bar or 116 PSI, I expected around 90psi?
Keith
kclewis wrote:OK, it was a top of the range pressure tester ( Cheap!) I will get the gauge checked tomorrow and replaced if no good and try again. Did you leave yours running with that pressure? Keith.
Users browsing this forum: No registered users and 61 guests
