small end smashed ?
small end smashed ?
Postby neil64 » Wed Jul 26, 2017 11:03 am
hi ,
anyone had this problem , completely wrecked top end on a cast iron 175. caused by a smashed little end bearing , the engine mileage maybe 5/600 miles , no real noticable noice untill i changed from 4th to 3rd at maybe 50 mph , thought a ring had gone , then locked up .luckily at a stand still.
neil64
Re: small end smashed ?
Postby rossclark » Wed Jul 26, 2017 11:47 am
Couple of options really that would cause small end failure
Lubrication failure - what oil and what % were you using?
Poor quality bearing
Failure to fit piston shims if crank not shimmed
Damage to gudgeon pin / small end eye on crank
