Breath Sweet
Breath Sweet
Postby Delboyli150 » Mon Jul 24, 2017 6:58 pm
Hi Guys just looking for general census on Carb Filters,
Looking at putting a breath sweet filter on my scoot but wonder Is it really worth it in this country?
I have had one before but realised the side panel was squishing the elbow on the hose, therefore every time I stopped at a Junction I lost power pulling away, took it off and everything was running fine.
As I am booked in for a Dyno at weekend, looking for some answers.
What I have noticed on my new build is the elbow will not be squished this time, but has got me thinking is it necessary at all.
Will only be doing around 4-5000k a year. A Mixture of A/B roads.
Delboyli150
Re: Breath Sweet
Postby jonno » Mon Jul 24, 2017 7:42 pm
It all depends whether your engine is getting enough air, which will show up on the dyno run.I had to fit one to get the carb to be correct. You may not need it .
jonno
Re: Breath Sweet
Postby lammydave » Mon Jul 24, 2017 8:42 pm
A breath sweet will touch the panels unless you have a nice short inlet manifold.... the best one I've found is the mb one..assuming you have a phbh.
lammydave
Re: Breath Sweet
Postby Scooterlam » Mon Jul 24, 2017 10:44 pm
Filters are a personal choice.
Up until this year I've run without one and my engine wear has been monitored by the kits designer.
Ring wear is the same as non filtered kits and new rings brings it back within tolerance so no bore wear.
No graining in the barrel.
Scooterlam
Re: Breath Sweet
Postby coaster » Tue Jul 25, 2017 7:43 am
Scooterlam wrote:Filters are a personal choice.
Is that the Avanti Derek?
Re: Breath Sweet
Postby Warkton Tornado No.1 » Tue Jul 25, 2017 11:45 am
Delboyli150 wrote:Hi Guys just looking for general census on Carb Filters,
You can also read how some of us have covered similar ground under:
Tuning & Kits: new 200 set up &/or Air filter options?
I hope that helps.
Re: Breath Sweet
Postby Delboyli150 » Tue Jul 25, 2017 7:40 pm
Hi Coaster
It is the Breath Sweet from Ramair purchased from CamLam.
Hi Guys thanks for feedback think I will just take it with me in case!
WK1 will look under that link, thank you.
Delboyli150
Re: Breath Sweet
Postby Strummer10 » Wed Jul 26, 2017 8:27 pm
Had my Avanti Dyno'd 2 months ago. Was running perfectly well with a breathe easy filter on (although marginally crushed the elbow by the panel). The dyno operator suggested it would run better without a filter so taking he's advice and after various jet size changes (122 down to 115 main jet) the job was done but it only achieved extra 0.5 bhp with panels off on the dyno exercise .....panels back on after which I presume must reduce performance (just wondering therefore should it not be dyno'd with panels back on to give a true road reading ?? )
Conclusion on riding to Belguim thereafter, it was slightly better on pick up in first and second gear but nothing otherwise.........personally I must confess it definitely run better with the filter on and was a first time starter (not now) :D :D :D so gonna get the MB inlet and use it again see how it fairs.
Strummer10
