Aluminium Blackening
Postby Angry Bloke » Fri Jul 21, 2017 10:41 pm
Has anyone tried to chemically blacken alloy ( with or without success) ?
I've got a bottle of " Birchwood Casey - Aluminium Black " which if it does what it says on the tin ,should be ideal :roll:
Angry Bloke
Re: Aluminium Blackening
Postby foremanbob » Sat Jul 22, 2017 2:17 pm
most of the home stuff you can buy works... but its a soft finish... normally scratches easily
foremanbob
Postby Angry Bloke » Sat Jul 22, 2017 10:27 pm
Thanks Bob
Angry Bloke
Postby coaster » Sun Jul 23, 2017 10:00 pm
Is it a form of anodising Peach? you normally need an electrical source and 'charge the item whilst it is suspended in a dye solution...did it at school a loooong time ago 8-)
Postby Angry Bloke » Mon Jul 24, 2017 2:09 pm
Thanks Colin - That's the type of thing but I was hoping for a more robust finish than anodising
I'm planning on trying it out on some test bits later :D
Angry Bloke
Postby Angry Bloke » Tue Jul 25, 2017 8:45 am
Well , it did a fantastic job on the stainless steel blade of the craft knife I used to open the bottle ..........
Shame I cant say the same for the alloy test pieces :roll:
Hammerite it is then
Angry Bloke
Postby Warkton Tornado No.1 » Tue Jul 25, 2017 11:37 am
Angry Bloke wrote:Well , it did a fantastic job on the stainless steel blade of the craft knife I used to open the bottle ..........
This might be a “I’ll get me coat” situation but, by accident, I found that dunking alloy parts in 'Vanish Oxi action' leaves them with a matt, dark grey finish that is surprisingly enduring & might look better than Hammerite. I did an alloy cylinder & head prior to honing/polishing the internal working surfaces.
I suggest you try it on something like an alloy seal retaining plate that won’t be seen first.
Postby Angry Bloke » Tue Jul 25, 2017 1:56 pm
I like the sound of that WT1 - I'll give it a try :D
Angry Bloke
Postby Fast n Furious » Wed Jul 26, 2017 2:12 am
Virtually any strong acid or alkali will have this affect on aluminium.
