TrackTen wrote:Is there such a thing anywhere on the web that compares all the spring weights etc of clutch springs from various sources so they can be easily compared ?
nsaints wrote:
SX150 standard - 11lbs (these are the springs that were in my unmolested SX150 when bought)
MB springs (New) - 16 lbs
MB springs (3000 miles) - 14 lbs
Scootopia springs (new) - 13 lbs
Cambridge Lambretta (ultimate, soft feel) (new) - 18lbs
GT (from Rich Taylor) (new) - 21lbs
No wonder I keep breaking clutch cables then with my YZ 80 clutch springs as they are rated at 45lbs (each) !
Dickie Wrote:
Saints; how/where did you measure? There is a consistency problem here. If someone replicates your method they need to apply the force at exactly the same point on the lever.
dickie wrote:
Scooterdude was talking about required force at the lever not directly applied to the spring.
Just to clear this one up. I had the springs from Harry Barlow who tested each spring in a thing that looked similar to a drill press but with a gauge on top, they each displayed a pressure of 45 lbs.
TrackTen wrote:Thanks for that Dickie
Interestingly after thinking about your findings I wonder if what we actually describe as a 'stiff' clutch is possibly the feel that the preload gives - ie the feeling of the pull required to get the clutch handlebar lever actually moving initially
