missing lynx wrote:I run a sip 2 speedo on an ac scooter without any problems when I first got it the book doesn't make it clear you can only access the menu when the screen displays the screen shown on the overview page once I found that out setting was easy I've been told the rev counter doesn't work so well on a dc set up I hope this helps you do need to run it off the scooters power as running off a battery won't give it the impulses it needs to give you all the functions
Delboyli150 wrote:Hi
Ready through many forums and speaking to many people there does seem to be either a bad batch, or just rubbish in the first place.
I am under the impression that once set up they are a good piece of kit, fingers cross, hope you resolve this quick. Just a thought can you 'borrow' one from anywhere@
Users browsing this forum: No registered users and 88 guests
