Sip speedo cable
Sip speedo cable
Postby Spursy » Wed Jun 14, 2017 7:51 pm
Had a sip speedo on for a while, just fitted one of the new cables to my hub ... just wondered what the sensor setting is for it .... any info would be greatly appreciated
Spursy
Re: Sip speedo cable
Postby coaster » Wed Jun 14, 2017 8:09 pm
I believe you need to set the menu to EXT and use the ratio as per the type of scooter in the table
Postby Spursy » Wed Jun 14, 2017 8:13 pm
I've fitted a few of these .. original cable and the magnetic type ... however 1st time I've used this type .. was set to external .. and tyre size .. it was the pick setting that's got me stumped ..says set to 6 as per instructions that come with it ....but that's pants ..
Spursy
Postby coaster » Wed Jun 14, 2017 9:20 pm
Spursy wrote:I've fitted a few of these .. original cable and the magnetic type ... however 1st time I've used this type .. was set to external .. and tyre size .. it was the pick setting that's got me stumped ..says set to 6 as per instructions that come with it ....but that's pants ..
I agree, the instructions are not very helpful, mine uses the remote sensor aimed at the wheel studs and works brilliantly now that I have set the pulses correctly. I think you have to set it to Internal and then set the speedo gear ratio according to the chart in the instructions. Good luck ;)
Postby Covboy » Wed Jun 14, 2017 9:42 pm
I ve got one and it works very well. The is setting is ext and diameter is 1001mm and its spot on with gps
I've got some additional instructions- I'll try and remember to upload them tomorrow
Postby Spursy » Wed Jun 14, 2017 10:01 pm
It's the pick up setting I need ..... got all the other settings
Spursy
Postby Covboy » Thu Jun 15, 2017 1:57 pm
My settings are : -
ADJ -2 = EXT
ADJ 3 = 1001
ADJ 3 = SP06
Postby Spursy » Sat Jun 17, 2017 12:41 pm
cheers lads .... sorted
Spursy
Postby Fast n Furious » Sun Jun 18, 2017 3:05 am
Covboy wrote:My settings are : -
ADJ -2 = EXT
ADJ 3 = 1001
ADJ 3 = SP06
ADJ3 should = 1000 to start with. This setting wants know how many speedo drive cable rotations there are per Km. ( 1610 revs per mile) In reality though. you need to make slight compensations based on tyre choice Tyre wear and tyre pressures.
ADJ 3 is the number of magnetic pulses produced by the sensor for one ration of the speedo drive.
Postby ULC Soulagent » Sat Jun 24, 2017 5:45 pm
Adj ext2
Adj 2 0675
Adj 3 sp4
ULC Soulagent
