by foremanbob » Tue Jun 13, 2017 9:21 am
Looking for a rear wheel carrier to hold a spare SIP tubeless....
Style similar to this... obviously the studs wont fit... anyone any bright ideas other than grinding out the short studs and replacing them?
foremanbob
by Solid Air » Tue Jun 13, 2017 9:47 am
Hi Bob, I had this problem so removed the four studs from the carrier and fitted M8 rivnuts in their place then secured the wheel in position with four bolts.
Hope this helps
Mark
by Toddy » Tue Jun 13, 2017 12:20 pm
Solid Air wrote:Hi Bob, I had this problem so removed the four studs from the carrier and fitted M8 rivnuts in their place then secured the wheel in position with four bolts.
Hope this helps
Mark
+1
by Granty » Tue Jun 13, 2017 1:59 pm
Guys, I used 4 extended cylinder head nuts, screwed them onto the carrier and then used 4 Allen bolts to fix the rim to the carrier, worked well.
Granty
by burnside » Tue Jun 13, 2017 10:23 pm
I used stud extenders/connectors on each of the existing studs, then bolt the rim in with M8 bolts
burnside
by rossclark » Thu Jun 15, 2017 10:54 pm
Granty wrote:Guys, I used 4 extended cylinder head nuts, screwed them onto the carrier and then used 4 Allen bolts to fix the rim to the carrier, worked well.
Also done this
Users browsing this forum: No registered users and 161 guests
