by Hornbyfrog123 » Mon May 29, 2017 3:23 pm
Advice required...
Have a 1972 series 2 li 150 with standard GP 200 engine and it has always had a Casa GP air inlet hose fitted but is this correct? or should it have the li type air inlet hose with breather pipe or does it matter. The scooter runs very well as it is set up.
Thanks in advance for any responses.
Lee
Hornbyfrog123
by Mel K » Mon May 29, 2017 6:30 pm
If it isn't broken don't fix it .
Mel K
by corrado » Tue May 30, 2017 1:30 am
If you have a GP hose fitted then I presume that you have a 22mm carb fitted? The Li type with breather are for 18 / 20mm carbs and don't fit the 22mm.
corrado
Users browsing this forum: No registered users and 213 guests
