Nordlock washers
Nordlock washers
Postby stephena » Fri May 26, 2017 10:11 pm
Evening all Just taken an sip tubless wheel of to get a tyre changed and the Nordlock washers have all come of in two halves. This is the first time I have taken the wheel of since putting it on about a year ago.The question is do the washers normally come apart? Thanks
stephena
Re: Nordlock washers
Postby ToBoldlyGo » Fri May 26, 2017 10:15 pm
The Nordlock washer is made up of two seperate parts, so it would, I imagine.
ToBoldlyGo
Postby stephena » Fri May 26, 2017 10:27 pm
So the next question can they be used again?
stephena
Postby Knowledge » Fri May 26, 2017 10:34 pm
Screwfix do a nordlock style washer, but cheaper.
Worth checking out
Postby dickie » Fri May 26, 2017 11:00 pm
stephena wrote:So the next question can they be used again?
Yes they can. We use loads at work. Just make sure that when you put them back on that you put the ramp faces in contact with each other. Otherwise they do nothing.
Postby stephena » Sat May 27, 2017 3:39 pm
Thanks for the replies tyre changed wheel back on reused the washers.
stephena
Postby corrado » Tue May 30, 2017 1:45 am
Knowledge wrote:Screwfix do a nordlock style washer, but cheaper.
Worth checking out
£8 for 20 but they're stainless steel. I'd be a bit reluctant to use these on the Sip rims as the teeth on the stainless ones are likely to "chew" into the alloy of the rim.
Once the 2 halves have been split be sure to put them back together correctly with the finer serrations on the outside, as per this pic.
corrado
