Vintage Plug Cap
Need help identifying that accessory? or just want to show off some of your Lambretta memorabilia? .......... This section of Anoraks Corner is for members to show off their Lambretta accessories and memorabilia.
Strict no chatter
Vintage Plug Cap
Postby Dimitrios_231 » Wed May 20, 2015 4:01 pm
This is my try (just for laughs) to replicate a pic that I always liked :)
Dimitrios_231
Re: Vintage Plug Cap
Postby Tractorman » Wed May 20, 2015 6:07 pm
I still use a KLG plug cap like that now :oops:
Postby Dimitrios_231 » Wed May 20, 2015 9:30 pm
If it ain't broke don't fix it :)
Both at 12KΩ
Dimitrios_231
Postby 69GP225 » Tue Jun 07, 2016 9:43 pm
Are these worth anything?
I have a few kicking around....
69GP225
Postby Dimitrios_231 » Wed Jun 08, 2016 8:16 pm
I don't know,I got mine very cheap,almost free.
Dimitrios_231
Postby Warkton Tornado No.1 » Thu May 25, 2017 1:27 am
Sorry that I've only just noticed this, but, although Lambrettas were factory fitted with suppressed plug caps, according to Bell, it's best to use non-suppressed & a fine wire plug with points ignition.
Perhaps that's why mine can be a bit fussy starting :roll:
Postby Dimitrios_231 » Thu May 25, 2017 11:19 am
I agree,with points ignition,you get a brighter and probably a better spark by using an unsuppressed cap.
A slightly updated pic.
Dimitrios_231
Postby Warkton Tornado No.1 » Thu May 25, 2017 11:40 am
This used to be quite a common modification in the days of road going 'sporting' scooterists. After all, the length of the standard HT lead is preferably reduced.
I can't think why I haven't done it myself, apart from reluctance to drill the frame!
Postby Chadley » Thu May 25, 2017 11:35 pm
Warkton Tornado No.1 wrote:I can't think why I haven't done it myself, apart from reluctance to drill the frame!
The extra heat this location gives from the cylinder up to the coil perhaps?
Chadley
Postby Dimitrios_231 » Sat May 27, 2017 10:26 am
Good point ;)
I don't use toolbox,plenty room for air,I don't have any heat issues.
Dimitrios_231
Return to Accessories and Memorabilia
