Feersum Injun wrote:Petrol in the float? Float needle sticking?? Choke engaged???
Warkton Tornado No.1 wrote:I could lend/send you a Dell'Orto 30 to substitute but it's solid mount. Is yours?
I feel your pain, BTW!
dscscotty wrote:Did you say in an earlier post a 400 fuel valve? also have you tried it with no fuel cap on?
Warkton Tornado No.1 wrote:With acknowledgements to Grandpa, this includes float height adjustments (pages 9-10):
http://www.rotaxjetting.com/PDFs/Docume ... Manual.pdf
mainstand wrote:If you inspect the reeds & find bits missing, take your exhaust off & rod it through, then shake it out. I've had broken reeds blocking my pipe up before.
nastro azzurro wrote:Try another tank.
I had very similar symptoms a few years ago and tried everything you have and more.
Last gasp was change of tank and all was perfect.
Tank didn't appear to be the problem, fuel flowed as it should through the tap and tap filter looked clean.
Obviously the vibration when running was making the debris in the tank interrupt the fuel feed.
Tank looked fine so didn't consider it to begin with.
Users browsing this forum: No registered users and 178 guests
