Digger wrote:The end of the Indian cable that fits into the speedo itself is about 3 times the size of an Italian one.
So an Italian inner in an Indian speedo will not touch the sides as you have just found out.
St George wrote:Just had similar issues. I fitted a new speedo to the wrong inner ( italian ) This in turn rounded off the drive inside the speedo. I have just ordered a new Italian Speedo, hope this does the trick.
St George wrote:Granty to some up my one.
Bought a new speedo two years ago. Inner cable too small and rounded off inner drive of speedo. Have fitted a new Italian speedo toady to my Italian cable. Job done
Tony Hart wrote:Just be thankful you are not trying to fit a Spanish S2 speedo. Indian inner but the outer cable nut is different again to both Italian and Indian cables. Ended up trimming down the nut from a v**pa outer cable.![]()
Turned out to be a complete waste of time, effort and money as I sent the speedo away for repair and never seen it since
JETEX wrote:Some inner speedo cables don't have a brass ferrule around the cable at the speedo end, so when it's all connected up, the inner cable drops down the outer just enough to disengage it from the speedo.
