engine mount holes
engine mount holes
Postby bluebob » Tue May 16, 2017 9:34 pm
can someone please remind me what position the holes should be on the two hole mounts.
bluebob
Re: engine mount holes
Postby bluebob » Wed May 17, 2017 8:34 pm
can anyone help me out as I cant find my manual .I have decent looking 2 hole mounts fitted.drive side the holes are at 5 to 12,and 5 past.Flywheel side is at quarter to 12, and 5 to 12.Anyone know if this is about right.?
bluebob
Postby gaz_powell » Wed May 17, 2017 9:42 pm
2 hole type voided type mounts
Flywheel side 8 and 10 o clock
Kickstart side 10 and 1 o clock
Postby Dennie » Wed May 17, 2017 10:09 pm
Hi, just checked in book and says Vulcan brand 2 hole mounts with the holes facing forward so that the kickstart side has holes at 2 0' clock and 4 0' clock.The flywheel side holes at 8 0' clock and 10 0' clock. These mounts have softer construction . Hope this may be of some help regards Dennie.
Dennie
Postby bluebob » Wed May 17, 2017 10:18 pm
cheers Gaz.
bluebob
Postby bluebob » Wed May 17, 2017 10:20 pm
and Dennie
bluebob
