lammydave wrote:aa card
CHRIS in MARGATE wrote:If you are competent and confident, then a tool of your choice to undo and retighten every nut and bolt on your scooter.
Go over your scooter with panels off and make sure you have the correct sizes for wheel nuts, front snd rear hub nuts, front/rear suspension, exhaust nuts, allen keys for cables and rear hub, running board nuts, plug spanner, cowling bolts, flywheel nut and flywheel puller, cylinder head nuts plus a means of getting carb off, screwdrivers, mole grips, chaincase nuts, (I carry a clutch compressor), etc. etc
.etc..... plus torch, hi - viz, phone.
Spares: plug, wheel and hub nuts, cables, plug cap, insulating tape, surgical gloves, wet wipes, toilet paper, water, snack bar, CDI, stator, head gasket, pre soaked clutch plates, gaffa tape. (I carry a spare piston)
The list is as long as your roadside capabilities. I promise you I have used all these at some point for myself or my friends. There is MORE ! Others will add to this as well. A good check of everything before you set off is essential.....plug, wheel nuts, cables.
I guess you'll consider staying home now!:(only joking)
jonoy wrote:AA card got that![]()
I was thinking of essential tools and spares.
jonoy wrote:so cables trunions spanners allen key ,plug spanner plugs ht lead
Users browsing this forum: No registered users and 67 guests
