Top bush for rear damper
Postby AAVlover » Mon May 15, 2017 4:32 pm
Hi - i have had the rear damper painted but the guy removed the bush at the top (why!) and cannot find it. No one seems to have one and i need to buy a replacement damper at 100 euros and have it painted.
Does anyone have an old/new bush????
AAVlover
Re: Top bush for rear damper
Postby St George » Mon May 15, 2017 5:37 pm
If you have the correct dimensions there is a great guy at Colchester who will send you one. NJB Shocks. He supplied a set for my old AJS, but will need the dimensions spot on. They will press in quite easy with fairy liquid. He is not into Lammies but very helpful. I would order two. Regards.
St George
Postby AAVlover » Mon May 15, 2017 9:52 pm
thanks St George, I'll contact him tomorrow
AAVlover
Postby AAVlover » Wed May 17, 2017 11:17 am
Norman can't help, it is too small - any other ideas?
AAVlover
Postby St George » Wed May 17, 2017 5:28 pm
What about Hagons of Hainault. ( Hagon Shocks )
St George
Postby AAVlover » Thu May 25, 2017 10:54 pm
No, the bushes are too small, found a new damper for £25, sorted!
AAVlover
Return to Pre 57
Users browsing this forum: No registered users and 28 guests
