Damper Bolt On Kits
Damper Bolt On Kits
Postby Nudger » Fri Aug 22, 2014 12:24 pm
Has anyone fitted these that can offer an opinion: are they worth using - do they really make a difference?
I've got a standard Li150 Special & am thinking about adding dampers to help improve handling & braking etc...
Any comment gratefully received.
Nudger
Re: Damper Bolt On Kits
Postby Scooter Paul » Fri Aug 22, 2014 1:48 pm
Fitting dampers is worth it. Using welded on upper brackets is best but providing you can get the clamp on type to fit properly no reason why not. Clamp on kits were available long before the Indians fitted them as standard.
Paul.
Scooter Paul
Postby Nudger » Fri Aug 22, 2014 3:58 pm
Thanks for the quick reply Paul - I was wondering if the clamps would be a bugger to fit properly.
Guess I might as well do it properly & weld the brackets on.
Nudger
Postby IaninDorset » Fri Aug 22, 2014 4:37 pm
I remember my mate had terrible trouble with clamp on types back when they were new, he tried everything from wedging, araldite (the stories that could be told of Araldite), I think he had a local firm drill and tap a couple threads and he put some studs in but they didn't last well and he gave up in the end. One of the wacky things I do remember was he tried converting a motorbike fork brace clamp but the thing would shift on a pothole and pull him into a ditch.
IaninDorset
Postby Nudger » Fri Aug 22, 2014 5:19 pm
Hmm not the handling I'm looking for Ian!
Nudger
Postby IaninDorset » Fri Aug 22, 2014 5:48 pm
Nor him I think but then he was the bodge artist of them all, he turned his metal lunchbox into an exhaust box rather than buy one for his LD he had lol
IaninDorset
Postby bazza3004 » Fri Aug 22, 2014 8:39 pm
Hi ive had the fork clamp brackets on my GP for 2k miles and as yet they havent moved at all.
bazza3004
Postby Revvers » Fri Aug 22, 2014 9:53 pm
I had bolt on brackets, and now I have weld ons and I don't notice any difference between the two. Dampers are definitely worth fitting imho
Revvers
Postby lammydave » Sat Aug 23, 2014 6:21 am
the LTH billet ones are the only ones to get... german engineering and quality
http://www.lambretta-teile.de/Front-sho ... -Lambretta
lammydave
Postby Custard » Mon Aug 25, 2014 5:05 pm
I had a pair of the LTH brackets one of them snapped after about 12 months possibly due to aluminium they are made out of being less flexible than steel.
Custard
Postby Nudger » Tue Aug 26, 2014 12:15 pm
Thanks for the replies - much appreciated....
Nudger
Postby terryj » Tue Aug 26, 2014 1:58 pm
i have the welded on tops with bolt on bottoms i find that my wheel axle nuts to links need to be re tightened on a regular (almost every rally) basis
terryj
Users browsing this forum: Google [Bot] and 46 guests
