S1 remade headset and horn case
Postby Watfordwhite » Mon Apr 24, 2017 7:52 pm
Just started a rebuild on a S1 frame breather. I'm missing the head set and horn case. In fact all I have is a frame.. So missing everything.
Found a re made option on eBay £220. Re made in India. Does any body have any experience with these?
Good, bad or leave well alone?
Better still if anybody has an original Please PM me or any spare parts for the frame breather?
Watfordwhite
Re: S1 remade headset and horn case
Postby steve c » Sun Apr 30, 2017 10:08 pm
these can be terrible,
very heavy and badly cast
you will find originals but the horn casts are expensive £250 to £400
pair of handlebars should go for around £150 with the clamp, and £250 with switch housings, gear change and rods
the scootrs pressed steel horncasts using a ser 2 round grill are good but where you will get one now is another issue now they are trade only ( try ressurection scooters or just lambretta)
theres a pair on ebay no 201902837485 loads of heat and dunk in a bucket of cold water repeatedly they do come apart eventually
steve c
Postby Watfordwhite » Mon May 01, 2017 8:48 am
Thanks Steve, I will leave the Indian stuff well alone. I may of found a complete set in Italy, just talking to the guy now. NOT CHEAP.... :shock:
Watfordwhite
Postby Topgearskin » Mon May 01, 2017 9:18 am
I bought some from India off eBay.
The casting was rough and the headset top and bottom were a pretty lousy fit. Took a lot of dremel action to get them in decent shape. The headset still needs a bit more work to get it perfect. The hornacasting isn't bad (although the grill was dreadful and there is a fillable nick at the top of the grill hole.
I complained to the seller (who had described them as "genuine" parts. Got a discount. Paid £150 including the postage
If you want to take a chance you can have them for what I paid as I haven't used them. My intent was to use the horncast on my API Lamby but I've never got round to making a bracket whilst I've rebuilt the engine
Like everything from India (except the flawless music) you pays your money, you takes your chance.
Topgearskin
Postby gaz_powell » Mon May 01, 2017 10:29 am
Consider fibre glass???
GRP scooter parts
Postby Watfordwhite » Mon May 01, 2017 1:50 pm
gaz_powell wrote:Consider fibre glass???
GRP scooter parts
I had considered fibre leg shilds , mudgard and panels to keep the weight down. Didn't know they did head sets and horn cases??? Now that's an idea. Thanks Gaz.
Watfordwhite
Postby Watfordwhite » Mon May 01, 2017 1:56 pm
:lol:
Watfordwhite
Postby ToBoldlyGo » Mon May 01, 2017 1:59 pm
GRP scooter parts
They do the horncast and the headset top. But not the bottom for structural reasons, I imagine.
ToBoldlyGo
Postby gaz_powell » Mon May 01, 2017 6:16 pm
Watfordwhite wrote:Like everything from India (except the flawless music) you pays your money, you takes your chance.
:lol:
TopGearSingh is right about both the parts and the music......Keep on Keema Nan!
Postby gaz_powell » Mon May 01, 2017 6:19 pm
Forgive my ignorance but is a S1 headset bottom same as S2?? Scooter restorations have API Lamby 150/Mac 175 bottoms at the good price - I used one on my S2 build
Postby modster79 » Mon May 01, 2017 6:52 pm
No, headlight on S2
modster79
Postby Watfordwhite » Mon May 01, 2017 6:56 pm
Gaz,
The head light on a S1 is in the horn case, where an S2 is in the head set. My avatar is my S2.
Watfordwhite
Postby gaz_powell » Mon May 01, 2017 9:05 pm
:oops: bloody hell, what I plank I am.....note to self engage brain before mouth - i've got a S2, so I do know the difference...... honestly!!! ;)
Postby Watfordwhite » Tue May 02, 2017 5:33 pm
Now found an original headset, tank flap, rear light and rear mudguard. Also a buddy seat in Italy.
So getting there
Watfordwhite
