The question is will a SIL replacement be ok
The engine is not being tuned so will be pretty much standard albeit has a 150 top end .
I'm just worried it may not stack up correctly
Thanks Phil.
hullygully wrote:providing the new gear has the same no. teeth, same o/s diameter (you need a vernier for this job) & the internals for the selector are the same
Phil D wrote:hullygully wrote:providing the new gear has the same no. teeth, same o/s diameter (you need a vernier for this job) & the internals for the selector are the same
Ok how do the SIL gears compare to genuine Italian ones generally?
[/URL]Users browsing this forum: No registered users and 159 guests
