Donnie wrote:As said, the front mudguard and horncast. However if its an original engine you may find that if you want to do anything cylinder wise that many if not all had been fitted with the shorter series one type cylinder and therefore the cylinder cowl too. Would be an issue if you want to put a different top end on, just order up a later cylinder cowl too
