Watfordwhite wrote:For all of you not at Scarborough. Just rebuilt my S2, complete ground up rebuild. Runs and starts fine. After running about 20 minutes it seems to suffer fuel starvation then if you pull the clutch in it revs really high like the choke is on full?
Turn off the ignition and restart and all is good again until the next time. The fuel tank was cleaned and there is an in line fuel filter. What's going wrong?
Rapido 225 with MB shorty reed and MB Clubman. 28mm Delorto carb with Ramair filter.
