Leotech wrote:Has it got a reed valve? broken petals?
bookertmgs1 wrote:Not very helpful - but if its only 40 miles away - are you not better cadging a van & bringing it home - especially if you don't know whats wrong with it
Looks like you've done the obvious stuff so open heart surgery seems daft when so close to home
if you've no van - try Shipley - you never know whether someone is in the area & up for a quick job
Donnie wrote:If you replaced the petals 50 miles ago is it possible they have worked loose? Just a thought.
Fast n Furious wrote:As advised above do check your reeds.
You say you measured 50v from your LT coil? I'm assuming that's 50 VAC? Only measure this on AC!
If so, this isn't enough and is a typical measurement that you will see from an iffy indian stator. If the symptoms seem to be that the scoot has developed a near perfect rev limiter then this is typical of a goosed LT coil.
Measuring the resistance of the coil won't tell you anything worthwhile. In my opinion its not worth the effort trying to fix it with spare parts. Just put a BGM stator in and be done with it. Its £40 for a piece of worthless crap and £80 for a peace of mind.
No brainer.
missing lynx wrote:I would suspect bad fuel my sons vespa had similar symptoms to yours when I drained his tank there was gobs of stuff that looked like fat so cleaned the tank put fresh fuel in and it was fine again
dscscotty wrote:My money is on stator and the stator you speak of are not the most reliable I can assure you, we done 4 new ones on our production racer last season, readings etc were fine, low tension coils over heating was the general consensus of opinion from some well respected electro wizzards.
or possibly a fuel starvation problem?
dickie wrote:Not an ignition problem. Runs really nice then all of a sudden goes flat and dies. But it takes a good 5 seconds to stop altogether. While it's cutting out I can see that it's still firing well as I had my strobe on and the spark is rock steady at 17 degrees.
Users browsing this forum: No registered users and 194 guests
