J range uprated front end
Technical help for Lui, Vega, Cometa, J50, Cento, J125, Starstream.
Postby jonno » Tue Apr 11, 2017 8:49 pm
Has anyone uprated their J range front end,ie brakes and dampers.....looking for ideas. Thanks
jonno
Re: J range uprated front end
Postby Rich Oswald » Tue Apr 11, 2017 10:25 pm
Have a look in " J Range Special" in Show Your Ride.
Postby jonno » Wed Apr 12, 2017 7:41 pm
I have J range forks in a s3 framed sprinter want to keep them as lighter than s3 forks.Would the Indian damper brackets that slip on the axle fit a J range front links?
jonno
Postby mickey c » Wed Apr 12, 2017 11:57 pm
If J forks are closer to Vega / Luna, there are wheel nuts that the lower dampers can bolt to.
If the same applies cut series 3 springs and rods along with series 2 fork link pivot bolts fit Vega forks for more 'beef' at I guess not much extra weight!
If J & Luna forks are chalk & cheese, I'm sorry for talking nonsense!
mickey c
Postby jonno » Thu Apr 13, 2017 8:55 pm
Thanks Mickey will look into it.
jonno
Postby mickey c » Fri Apr 14, 2017 12:11 pm
No problem
In case it will be of use & interest to you, I did what this clever chap does in this link.
http://lunaownersclub.lifediscussion.ne ... rk+rebuild
mickey c
Postby jonno » Mon Apr 17, 2017 7:20 pm
Thanks mickey a great site do you know of anywhere I could source the axle nuts from?
jonno
Postby mickey c » Tue Apr 18, 2017 7:04 pm
These are the ones
https://www.riminilambrettacentre.com/e ... mburo.html
I'm sure I've seen them somewhere else, possibly one of the German shops but my memory is shocking!
Alternatively I drilled & tapped the end of the axle bar to fit the lower damper bolts, but maybe not ideal for your race purposes!
mickey c
Return to Luna & J Range
