Blaginit wrote:Reedspeed stourport on Severn Jerome will also give u advise if needed over the phone
coaster wrote:Blaginit wrote:Reedspeed stourport on Severn Jerome will also give u advise if needed over the phone
BrilliantI have an SSC clutch, even have a spare set of corks and uprated springs but one of the steels is warped so it slips like buggery. Very light action though and a lot smoother than the AF Road. I've tried without success to contact Morris that designed the SSC clutch, just wanted to know which Jap bike they came from.
bamrattle wrote:coaster wrote:Blaginit wrote:Reedspeed stourport on Severn Jerome will also give u advise if needed over the phone
So where did you get the spare plates and uprated springs from then Coaster
Adam_Winstone wrote:The one that I have came with a GP centre/pressure plate. Do we know if an LI/SX type centre is available?
Thanks in advance.
Adam
bamrattle wrote:Adam_Winstone wrote:The one that I have came with a GP centre/pressure plate. Do we know if an LI/SX type centre is available?
Thanks in advance.
Adam
It comes with a choice of centres adam gp & Li. Im using the Li option.
Normal lammy springs aint interchangable with this unit, But they do twist inside. But its impossible to pull the clutch lever in when you try it.
So the oly option is heavier springs to suit the ssc unit. And were still no further up the road with any help.
So i might go down the af cassette road clutch route now. The ssc would be a great unit on a standard engine, but not for anything better.
coaster wrote:I must admit I took a bit of a punt when I ordered the springs and I'm not 100% certain they will fit but I will pull the SSC clutch apart tonight and check they fit. Then I will see if I can figure a way of measuring the tension.....suggestions welcomed
Users browsing this forum: No registered users and 49 guests
