Holed piston - Mugello 200
Postby Dragbart » Wed Apr 05, 2017 8:19 pm
Muggy 200
JL3 pipe
26 Delly
Varitronic
Camlam mapper box
Dyno'd by Charlie Edmunds so set up correctly 18 months ago
Went to Clacton Ride Out in Sunday and scooter running fine until the ride home.
Running at 55-60 two up, when engine backfired and coasted to a stop. No compression so took panel off and spark plug was clearly loose. When I got it out it was white as in the picture below. Just got out in the garage and it's clear theres a hole in the piston as per photo taken through the plug hole.
I've got a couple of questions:
1. Could the spark plug have come loose and created a technical leak turning the mixture lean and creating heat, white plug and blowing the hole?
2. The engine turns easily now and seems smooth. Can this be fixed by merely replacing the piston/rings etc?
3. Can the piston be replaced by dropping the front end and taking barrel off with the engine remaining n the frame?
Appreciate any thoughts as want to get back on the road asap
Sorry photo files are too big
Dragbart
Re: Holed piston - Mugello 200
Postby Warkton Tornado No.1 » Wed Apr 05, 2017 9:08 pm
Yes, most definately.
Hopefully, but you need to inspect the barrel fully.
More than likely, but I'd have a good look/feel of your crankshaft with the limited access whilst doing so.
Postby holty » Thu Apr 06, 2017 9:00 am
if i were you i would remove the engine and take out the crank to give it a good clean, especially the big end, you might be able to wash it out in situ, but any debris could damage your engine, when rebuilt i would do a leakdown test just to be on the safe side, also check your carb for any blockages, also check fuel flow rate from the tap, when up and running also do a plug chop to check your not running weak or get it dynoed just to be sure,
good luck ,
holty
holty
Postby coaster » Thu Apr 06, 2017 9:37 am
Holty is right, the best way would be to completely strip the bottom end as it will be full of powderised aluminium from the hole in the piston which could find its way into the seals and cause you problems later. That said, I blew holes in 2 pistons on my Muggy 186 a few years ago and just flushed the crank case out with copious amount of WD40. I just kept spraying it in until there were no more particles in the liquid running out. I didn't have any more problems with that engine 8-)
Postby Dragbart » Thu Apr 06, 2017 9:47 am
Cheers for comments.
Coaster when you flushed with wd40 was the engine in situ or did you have it out the frame?
Dragbart
Postby CHRIS in MARGATE » Thu Apr 06, 2017 10:49 am
Copious amounts of WD40 means copious. In the past I have used old petrol and oil and finished off with more WD40.
I tell you something; just when you think it's all out, lo and behold a dribble more comes out. Keep spraying in and rotating flywheel. Don't proceed any further until you are 100% satisfied it's all clear. And wash the transfers out as well. You should be OK. Lots of us have done it.
When you rebuild you must check the spark plug colour regularly.
Postby Warkton Tornado No.1 » Thu Apr 06, 2017 11:40 am
Feedback is appreciated by all of us, so images will always be interesting to see, especially the underside of the piston crown & bore.
As ever, caution should be taken with the bottom end, but if the piston is holed because of a weak mixture, the result is literally burning through of the piston crown.
Unlike a smashed piston, any debris will go out through the exhaust port/pepper the head whilst the burn is taking place. Only when the hole is established can any crap go through the crown toward the bottom end. :)
However, repeating myself:
Postby Dragbart » Thu Apr 06, 2017 11:45 am
Deffo gonna try washing it out. Will finish with wd40 as suggested but how did you wash with fuel, I'm thinking some form of teat pipette - or a bigger turkey Baster to spray it in/around??
Dragbart
Postby Warkton Tornado No.1 » Thu Apr 06, 2017 12:04 pm
Dragbart wrote:Deffo gonna try washing it out. Will finish with wd40 as suggested but how did you wash with fuel, I'm thinking some form of teat pipette - or a bigger turkey Baster to spray it in/around??
Get yourself some of these:
(Medical Swab Sticks)
Postby Marty ULC » Thu Apr 06, 2017 3:51 pm
On the way home from geezleweezle we cleaned up after my holed piston by using an oil bottle to slosh spare petrol into the crank whilst kicking it over vigorously.
Marty ULC
Postby MickYork » Thu Apr 06, 2017 5:40 pm
I'd do a leak test before stripping it down.
Postby Dragbart » Thu Apr 06, 2017 10:02 pm
Thanks everyone for your help and advice. I'm off to Camlam on Saturday to pick up a new Muggy piston for the GP rebuild and some fork links for my old Jet that I'm playing about with .....then its garage time. When I get the piston out I'll put some pictures on here.
Mark
Dragbart
Users browsing this forum: Google [Bot] and 50 guests
