Jockeys Boxenstop headlight
Postby spud » Mon Apr 03, 2017 9:48 pm
Anyone installed one & have the wiring diagram?
Mine came without one :shock:
spud
Re: Jockeys Boxenstop headlight
Postby Tractorman » Tue Apr 04, 2017 8:23 am
You don't really need one because you are just reconnecting to another headlamp unit, you may get the dip and main mixed up but that's all.
Postby Phil D » Tue Apr 04, 2017 8:48 am
I've heard about these do they do them for Li 125/150 round type or SX only?
Phil D
Postby Donnie » Tue Apr 04, 2017 9:00 am
Tractorman wrote:You don't really need one because you are just reconnecting to another headlamp unit, you may get the dip and main mixed up but that's all.
Exactly, you are doing a direct replacement of three wires from your old headlamp to three for the new one.
Phil D wrote:I've heard about these do they do them for Li 125/150 round type or SX only?
No, they do them for all models except the GP mate.
Donnie
Postby spud » Tue Apr 04, 2017 12:44 pm
i mean for the wires from the headlight, they don't match the existing headlight & i don't want to blow the bulbs?
spud
Postby Tractorman » Tue Apr 04, 2017 2:51 pm
Take the two wires going to the headlight bulb connector, might be blue and red and connect to the two wires to the JB unit. You may get these the wrong way around to start with but no harm will be done just swoop them over. The wire to the parking/side light goes to the new unit side light and the earth goes to earth. There is really nothing to it.
Postby MK Monty » Tue Apr 04, 2017 4:32 pm
I think you must have a combined headlight bulb holder with festoon sidelight and connection block.
In that case it's a little bit more involved. Basically you need to loose the bulb holder and connection block. If it's an LI or special you will be a bit tight for room anyway. If you look at the lamp holder you will have several colours in cluster linked together eg all the Browns greens purples etc. the blue and the red feed dip and full beam with whatever colour going to the festoon bulb. That's your rubber morning mounted sidelight bulb the other end goes to earth. You can get some connectors called wago connectors with little orange locking levers. They come in 2,3,4,5 connectors the most you will normally have is 3 connected together. Cut the old bullets off cut 10mm or so sheathing off and stuff it in a hole pushing the lever down to lock it in. I would tin the wire with solder first. Never had one come loose in use but you can lift the lever to remove something and reuse. It's worth doing as the light is 1st class.
MK Monty
Postby Phil D » Tue Apr 04, 2017 9:14 pm
Does this help?
Phil D
Postby coaster » Tue Apr 04, 2017 10:30 pm
I see you have the Jet fitting there Phil, I have one too and it's right pain compared to the Italian fitting on my LiS :?
Postby Phil D » Wed Apr 05, 2017 10:36 am
:oops: Unfortunately Coaster it's not my machine I just found the picture on the net and saved it for future reference .
It looks a good bit of kit and I liked the look of the new scotch blocks .
I will add it to the list of upgrades ,with all the "tinkering " I wonder if I'll get any riding in. ;)
Phil D
Postby spud » Wed Apr 05, 2017 4:28 pm
Cheers Phil D
thats what i needed :)
spud
Postby La chevre » Tue Mar 27, 2018 7:27 pm
Hi
See in the pics i have one 5 wires on the JBS and four on the existing lamp holder (S1).which wire on the JBS is the earth think i know the main beam and dip these will be the red and blue on the existing bulb holder. Any info appreciated from our circuit wizards out there!
La chevre
Postby Marty ULC » Wed Mar 28, 2018 4:43 am
I'm no electrical wizard but if it were me I'd try wiring the brown to the yellow (side light) and connect the black along with whichever one of the other 3 wires you've worked out aren't main or dipped (red and blue) to earth.
Marty ULC
Postby Toddy » Thu Mar 29, 2018 1:56 pm
There's instructions on Jockeys website
Belegung: The wires:
weiß = Abblendlicht white = low beam
grün = Masse green = earth
blau = Fernlicht blue = high beam
braun = Stand-/Stadtlicht brown= city light
schwarz = Masse black = earth
Postby hullygully » Thu Mar 29, 2018 6:23 pm
strewth aint you European :lol:
Postby Micky67keane » Fri Sep 03, 2021 9:31 pm
Hi,just bought one of these for my LIS,does anyone have any fitting instructions.I get the wiri g but its the actual mounting of the light im not sure of,I have a ring and some other bits,including an oval junction block(probably going to use Wagos rather than this block,just to save room)
Any help appreciated,thanks.
Micky67keane
Postby bike grim » Sat Sep 04, 2021 9:01 am
You have to bend the lugs on the ring (2 pairs of pliers work) to match up with the bolt holes on the light from memory. Think Dog leg type bend. Bit of a faff but once you’ve got your head round it, straight forward.
Postby Micky67keane » Wed Sep 15, 2021 9:12 pm
Fitted Jockys light and replaced halogen with H4 highpowered LED bulb,WOW!!!
The difference is literally night and day.
Micky67keane
Postby lammydave » Fri Sep 17, 2021 6:40 am
Phil D wrote::oops: Unfortunately Coaster it's not my machine I just found the picture on the net and saved it for future reference .
Was my scoot, Spanish wiring it a spaghetti at best!
lammydave
Users browsing this forum: Baidu [Spider], Google [Bot] and 89 guests
