Norrie Bodge wrote:Before splashing the dosh on another gearbox m8?
Which may also include the need of a 47-tooth cassette AF crownwheel buying to get your gearing correct??
Try changing ya front sprocket to 18 tooth
Depending on your chain you may need use a pull down tensioner likes?
Using 18x46 will give you a final drive = 5.1
That should be ideal for you? A mate is similar weight as you?
ALAS he uses An LI-150 gearbox on his RB but he adjusted his to a final drive = 5
& he loves it recons pulls great uphill & in wind no bother![]()
Good luck
kdodd wrote:tempted to try and clean the clutch up as well, af 6 plate is really stiff compared to others just fitted new mb cables and inners but stiff pretty stiff doesn't help breaking my wrist on wway to isle of white last year but still think its stiff, read that you can clean up the drive sprocket casing slightly and slides better , is that true
Users browsing this forum: Baidu [Spider] and 61 guests
