Warkton Tornado No.1 wrote:Some facts about wire thread inserts, the correct generic term (commonly called Helicoils though that is a brand name)
• They are used extensively as the primary means of creating a threaded hole in very critical, stressed areas such as in racing vehicles & aerospace.
• They are designed into & fitted from the outset, not just as a means of repairing a thread.
• They are considered stronger & far more durable than the parent alloys that they are fitted into.
• In the event of a thread failure, they are normally replaceable as an easy fix, far quicker than other alternatives.
Of course, that’s not to say that Boeing etc have never, ever got their mate from the pub to weld up a stripped hole in a wing section, but I think it very unlikely....
Phil D wrote:Thanks for all the replies and kind offers of loan of kits .
I Phoned a insert stockist today to find out what sizes they stocked and got some useful info I wasn't aware of.
The taps contained in the kits are special and cut a unique thread for the insert the angle of the pitch helps the insert "bite" into the hole your repairing which makes perfect sense .
I'll have a better look at the weekend but it looks like someone has wound and M7 bolt in the hole instead of doing a proper repair![]()
I'm totally on board with the thread insert idea![]()
It seems salvageable and I have options but as WT says welding will be the last resort.
Will post the outcome.
Phil D wrote:Thanks for that WT1 so theres a good chance I may get away with running an M6 Helicoil tap down the hole and
an M6 Helicoil will work, would you use a dab of Loctite on the insert ? for a belt and braces effect.
Users browsing this forum: Google [Bot] and 80 guests
