I need a head gasket for a small block, 65mm. It uses the traditional 4 stud arrangement.
Who offers head-gaskets of 65mm. I know I could alter a traditional one, but I am so busy with other stuff at the moment, I haven't time.
Adam_Winstone wrote:If you are machining the head, what on earth are you considering a head gasket for?! A head gasket is simply a weak link to fail/blow and with your knowledge, ability and skills you should be able to design out this weak link.
Adam
