GT 200 30mm dellorto / BGM
Postby compass » Mon Mar 20, 2017 12:05 pm
Hi Guys , running above with following..
130 main
55 pilot
AV 268
X13 2nd clip down
Runs absolutely fine when revved past quarter throttle, however around quarter throttle its very boggy and rich.
Should I move clip?
Anyone else running the same?
Cheers 8-)
compass
Re: GT 200 30mm dellorto / BGM
Postby coaster » Mon Mar 20, 2017 8:11 pm
Have tried lowering the needle?
Postby Donnie » Mon Mar 20, 2017 8:23 pm
Cetainly sounds like you need to lower the needle, ie top clip and see.
If it's still boggy you may either want to try an x7 (slightly weaker needle) with the AV268, or go to a AV266 atomiser and stick with the x13
Donnie
Postby compass » Mon Mar 20, 2017 10:31 pm
Will try lowering the needle at weekend and will let you know.
compass
Postby swissdean » Tue Mar 21, 2017 2:06 pm
coaster wrote:Have tried lowering the needle?
+1 had same, raised clip to top and all fine
swissdean
Return to Carburettors
