grandpa wrote:Hi Harp2
Is the speedo bulb working?.The rear lamp is powered by a black wire coming from the same connector as your speedo bulb.Check black wire at rear with meter.swop over the speedo and rear light connectors at the headset..Does black wire from headset to rear have continuity? Check that black wire from ignition switch is plugged in.You will probably find you have a bad connection where black wires are plugged into headset junction.
Good luck
Grandpa
Wack wrote:With the ignition switch on the second click there should be power out on the yellow and black wires so unplug from the headlight connector block and test. You say the pilot is working so check the black has power. If not then the switch is faulty, but if it has power then check with a meter that you have continuity through the bullet terminals.For the front light to go out when you run a wire from the rear light may suggest a short in the rear bulb holder.
Wack wrote:Ignore the h/ bar switch as you have dip and high and presumably a horn so you need a tester ,either a meter set on ac volts or a test bulb to connect to the black and an earth. If the black gives out no power on the second and third positions of the ignition switch then it is at fault or it's black wire is damaged or loose on the connections.
harps2 wrote:Wack wrote:Ignore the h/ bar switch as you have dip and high and presumably a horn so you need a tester ,either a meter set on ac volts or a test bulb to connect to the black and an earth. If the black gives out no power on the second and third positions of the ignition switch then it is at fault or it's black wire is damaged or loose on the connections.
OK I can test that tomorrow thanks - headlight switches on with ignition at 2nd/3rd so I guess ign switch is working but maybe not for black connections - will update tomorrow.
EddieStone wrote:I still think you should check the earths.
Having voltage at a bulb is all well and good, but it needs a proper earth or it will find a random way.
Warkton Tornado No.1 wrote:Reading this Post, it’s fair to say you are gaining knowledge & confidence, with the help of all the contributors.
If I were you, now, I would take a long piece of cable & connect in any old how a bulb (12v speedo bulb will do) with a flying lead that you can touch to earth.
I would then ‘prove’ that it works by connecting to the correct terminal (that works!) in your headset & earth wherever you feel like around the back light.
As you go through the procedure, try the rear bulb contacts (there should only be one earth) which should be the only one to allow the test bulb to light.
Now disconnect the headset end & touch your test (non earth) wire to rear light (non earth) terminals & if your test light works, you know you have a fault within the rear light itself.
I apologise in advance if this response in anyway seems patronising, but this method is a visual check rather than just using a meter, which is what most of us would do.
harps2 wrote:Warkton Tornado No.1 wrote:Reading this Post, it’s fair to say you are gaining knowledge & confidence, with the help of all the contributors.
dave81 wrote:Hi harps2
Have been following your problem with the light. Grandpas last comment made me remember a problem I had with my rear light which may help. I could remove the bulb with the light on and when I put it back in the light didn't work. I found that the insulated disc in the bottom of the bulb holder was worn and turning when I put the bulb in so that the contacts were not lining up with the bulb contacts.
harps2 wrote:Well here's the latest and unfortunately not good.
I suspected the rear bulb holder so at much expense ordered a new one and fitted today - Still NO REAR LIGHT !
I have checked from the headlamp with a wire plugged into correct black wire point (12v speedo bulb attached) and using the earth point of the rear lamp - It lights up.
I have tested with a meter from black wire in headlamp to black wire at rear lamp - no problem continuity OK.
All earths are OK and checked
All other lamps are working, speedo, festoon , horn H/L etc etc
I am stuck !!!!!!!! - please help me out here, i'm nearly there and want to get MOT done this week- any suggestions??????????
Users browsing this forum: Charliescooter and 218 guests
