Bedding in TS1 rings?
Postby Lammer205 » Wed Aug 13, 2014 5:11 pm
How many miles do new Ts1 rings need running i for? thanks
Lammer205
Re: Bedding in TS1 rings?
Postby speedy » Wed Aug 13, 2014 11:42 pm
For me Zero miles, never have done and never any issues as they are very good quality. I would only run in if it were a new piston and rings,cheers,Speedy.
speedy
Postby Toddy » Thu Aug 14, 2014 6:20 am
50-100 miles then wang it :D
Postby berniek » Thu Aug 14, 2014 11:01 am
I do not understand the question! :D
berniek
Postby gaz_powell » Thu Aug 14, 2014 11:44 am
None - just do as you should always do - warm it up before you give it some stick
Postby corrado » Fri Aug 15, 2014 1:31 am
1. put key in ignition, switch to on position.
2. start scooter by means of kick start.
3. job done.
[Alledgedly]*
corrado
Postby Lammer205 » Mon Aug 18, 2014 7:21 pm
Thanx for all the advice, i have taken onboard all of your advice so i start the scoot a quick run up the local road ok it's running back home pack the for the weekend and then another 120 miles up the motorway flat out, so rings now well bedded in. ;)
Lammer205
Users browsing this forum: Baidu [Spider] and 18 guests
