mr mugello wrote:Best I get a holder made up then. Thanks for good advice.
mr mugello wrote:Torquing up the rear hub by using the brake . Is it ok to do it this method ok if you don't have the holder to hand.
Adam_Winstone wrote:WT1... for someone who is so keen to do things properly, your response above surprises me... you're so lazy!
lammydave wrote:mr mugello wrote:Best I get a holder made up then. Thanks for good advice.
martin at just lambretta has some for sale
http://www.lambrettaspareparts.com/page33.htm
Adam_Winstone wrote:^... WT1, I thought you would like that and was kidding about the 'lazy' bit.
"More a case of thinking it through & application of sound engineering principles.", OK, talk me through this then... when setting the rear hub nut to torque down the hub, if you're applying the rear brake, what are you actually torquing to, the shoes's ability to stop the rub rotating or the nut's torque setting to the layshaft? If looking at it from engineering basics, why introduce a factor that influences additional resistance to an assembly that is meant to be torqued to represent the tightness of nut on layshaft? In the same way that you should never undo a rear hub nut to allow a locking plate hole to align with the threads for the grub screw, as it releases pressure on the cone (initially torqued tighter) and can result in it subsequently coming loose, why would you apply a brake that resists the hub from pulling onto the layshaft (as well as rotation of) and assume that the torque setting remains constant once you release the pressure that the brake is applying to the hub? If the action of the brake simply exerted force in one direction then fair enough, however, the application of brake also applies force as a lateral restraint to hub movement. Considering that the whole ideal of the torque setting is to apply a known range of lateral force of nut - against hub - against cone - against layshaft, anything you do to alter these lateral loads (like apply a twin shoe'ed brake assembly to resist rotational movement but at the same time resist lateral movement) will totally throw that torque setting out of accuracy.
As I suggested previously, "Yes, it can work. Yes, it does work. Is it best practice?.... No.", which still stands.
Adam
Adam_Winstone wrote:^... agree 100% that there are times when this is the only method available and I too have used it over and over again, although involving my wife normally complicates matters. On the bench the holding tool works a treat, especially when pulling the layshaft home for shimming the gearbox, and now in most cases (for the sake of 4 nuts) will fit the holding tool, rather than applying the brake, if the bike is at home and the holder is available. I consider this to be 'best practice'.
It seems like most of us have used the rear brake method, and continue to do so, but it is not my first choice for the reasons that I've outlined.
Adam
Users browsing this forum: No registered users and 87 guests
