Alloy runner strips
Alloy runner strips
Postby mr mugello » Fri Mar 03, 2017 9:56 am
Fitting pattern runner alloys on legshield. The outside pair cover a hole on legshield. Should a hole be drilled in alloy channel for bolt fitting ? Thanks
mr mugello
Re: Alloy runner strips
Postby Andie » Fri Mar 03, 2017 10:26 am
Is that the hole for the flat headed nut and bolt combo that holds the mudguard on?
Andie
Postby HxPaul » Fri Mar 03, 2017 11:05 am
Their the lower mudguard fasteners and should be fastened first.If you've got a 2nd edition copy of Stickys book,its in there on page 237.
Postby corrado » Fri Mar 03, 2017 11:06 am
It sounds like the holes for the "top hat" fitting on either side.
http://www.scootopia.co.uk/product/7144 ... 50099-each
corrado
Postby mr mugello » Fri Mar 03, 2017 12:24 pm
I'm away from scoot at present to check , but is there a screw head the that the runner cover's over without needing to go through the metal channel ? The old runner s I took off were pattern from 15 odd years ago and are the same as my new replacement ones. Was reading Paul Slacks Lambretta restoration blog on LI series 3 and he mentions he had to drill a missing hole out . This is why I'm not sure how and can't remember how my old runners were fixed down here.
mr mugello
Postby HxPaul » Fri Mar 03, 2017 1:24 pm
The only screw heads that are under the floor channels are the bottom mudguard securing screws.These are on the inside channel not the outside.
Postby mr mugello » Fri Mar 03, 2017 2:20 pm
Thanks for info. Will check back tonight to see what's what, but a hole either side is covered over completely by one of the channels on both matching sides
mr mugello
Postby mr mugello » Fri Mar 03, 2017 6:04 pm
I apologize. Checking back. It's the inside pair of channels, which are covering the bottom mudguard hole up. Is this how it should be ?
mr mugello
Postby mr mugello » Fri Mar 03, 2017 6:08 pm
HxPaul wrote:The only screw heads that are under the floor channels are the bottom mudguard securing screws.These are on the inside channel not the outside.
Should it be a countersunk screw head under the metal channel for correct fitment hear ?
mr mugello
Postby mr mugello » Fri Mar 03, 2017 6:30 pm
HxPaul wrote:Their the lower mudguard fasteners and should be fastened first.If you've got a 2nd edition copy of Stickys book,its in there on page 237.
I've got it know mate. Can't believe I missed it. Even shows you the picture !
mr mugello
Users browsing this forum: Google [Bot] and 196 guests
