Correct size nyloc nuts
Postby mr mugello » Wed Mar 01, 2017 12:51 pm
I'm just after zinc wheel nuts. The ones I bought for my standard series three rims , the nyloc didn't touch the stud threads even with just a thin wavy washer fitted. Where can I get hold of the correct size of dome and plain nylocs with 14mm socket size in zinc ? Thanks
mr mugello
Re: Correct size nyloc nuts
Postby Toddy » Wed Mar 01, 2017 1:19 pm
E Bays a good bet link below to just one of many dealers on there , i would get Stainless grade stops the rusty look
http://www.ebay.co.uk/itm/A2-STAINLESS- ... HGdP4RxPmg
Postby mr mugello » Wed Mar 01, 2017 1:51 pm
Cheers Toddy. I'm trying to get the 14mm spanner size. These seem hard to get hold of. For a 64 special restoration.
mr mugello
Postby Toddy » Wed Mar 01, 2017 2:10 pm
mr mugello wrote:Cheers Toddy. I'm trying to get the 14mm spanner size. These seem hard to get hold of. For a 64 special restoration.
I see them will be 13mm spanner I think
Postby gaz_powell » Wed Mar 01, 2017 2:23 pm
Postby Phil D » Wed Mar 01, 2017 3:01 pm
Blimey that's some mark up !
Toolstation =£2.97 inc vat per 100
And you'll be able to see there on tight ;)
Phil D
Postby mr mugello » Wed Mar 01, 2017 3:28 pm
gaz_powell wrote:http://www.scootopia.co.uk/product/7441-3320/Scootopia-Lambretta-14mm-zinc-domed-wheel-rim-nut-set-15044110-set-of-4
Cheers these are the ones. Just need the 14 mm plain nylocs to finish my wheel sets
mr mugello
Postby HxPaul » Wed Mar 01, 2017 3:49 pm
I think the ones you are using are the deep nylocs and the thread on the studs wont reach the nyloc part of the nut.These are the correct spanner size,but I dont know about the depth of the nut,they're not cheap though.http://www.scootopia.co.uk/product/7272 ... -wheel-rim
Postby mr mugello » Wed Mar 01, 2017 4:40 pm
Cheers hx. I saw these. They are pricey like you say. Gets a bit too much for just nuts only ,on three sets of rims. Was looking at the zinc keeping in line with fork and spindle bolts fitted which are zinc .
mr mugello
Postby Wack » Wed Mar 01, 2017 7:05 pm
Got mine from here http://www.scooterrestorations.com/lamb ... ite-nyloc/ They also do the dome headed ones.
Postby mr mugello » Wed Mar 01, 2017 7:15 pm
These are the ones I bought . Studs not reaching the nyloc !
mr mugello
Postby Wack » Wed Mar 01, 2017 8:54 pm
Yes you're right, about 2 mm too high. I never checked when bought, just put in the drawer for future use.
Postby mr mugello » Thu Mar 02, 2017 11:09 am
Sod It. Gone for 13mm stainless. For the sake of 1mm ! Hopefully Scootopias GP ones are correct height and . Not messing about on safety relying on a few little nuts
mr mugello
Postby ToBoldlyGo » Thu Mar 02, 2017 11:36 am
I know you like it to look the part, but I'm not confident with domed nuts. The only way to be sure is to use standard nylocs all round. Maybe a colour co-ordinated dab of paint on the top of the studs so you know which is which.
ToBoldlyGo
Users browsing this forum: dave81 and 58 guests
