Digger wrote:No problems getting the bung through the tyre Adam?
I guess the scooter tyre being a lot smaller than a motorcycle makes it a little more rigid when deflated.
coaster wrote:Slight thread drift but has any one run with a split rim on extended studs? I can't see why this wouldn't work with some spacers, any thoughts?
HxPaul wrote:coaster wrote:Slight thread drift but has any one run with a split rim on extended studs? I can't see why this wouldn't work with some spacers, any thoughts?
If you use open wheel nuts,you wont need spacers.
EddieStone wrote: The mechanic said that plugs were the only approved form of repair for a tyre, but they should not be used long term and the tyre should be replaced as soon as possible.
Personally, I've ridden many miles with inner tubes with repair patches, whether I would now is unlikely, but a replacement inner tube is easy to carry and is a quick and easy repair.
