Aldi Bargin
Aldi Bargin
Postby P D: SC Chester » Wed Feb 22, 2017 8:07 pm
Was being dragged round poor man's Tesco today and came across a caliper for 7 squid. Managed to hide it in with the spuds without being collared by her in doors.
Any tips for doing the Squish on a 175?
P D: SC Chester
Re: Aldi Bargin
Postby Stevepshipley » Wed Feb 22, 2017 9:20 pm
Those digital verniers are a bargain, also noted they've got the tap and die sets in again for about £14. Great tools at great prices in Aldi
Stevepshipley
Re: Aldi Bargin
Postby Phil D » Thu Feb 23, 2017 7:19 pm
Thanks for the tip Chester . 8-)
I nipped in to Aldi on the way home from work this Afternoon and bagged the last vernier on the shelf .
I didn't manage to find the tap & die sets never mind I have a set .
:D
Phil D
Re: Aldi Bargin
Postby P D: SC Chester » Thu Feb 23, 2017 8:48 pm
Sound lads.
I must have missed the taps, but bought a set of spanners I didn't need, oddly, they actually say 'Aldi' on the chrome, doubt they will be Snap on' standard, but the look well made.
Now how do ya squish?
Tips welcomed.
P D: SC Chester
Re: Aldi Bargin
Postby Warkton Tornado No.1 » Thu Feb 23, 2017 10:34 pm
P D: SC Chester wrote:Sound lads.
Tips welcomed.
Presumably you haven't got Sticky's excellent 'bible' which I would recommend. With acknowledgements to:
http://www.gasgasrider.org
which has a good diagram:
You measure the squashed solder that results in turning the piston once past TDC.
I hope that helps, in layman's terms.... :)
Re: Aldi Bargin
Postby Paulnobodyimportant » Fri Feb 24, 2017 12:50 am
Bought some great tools from Aldi to use on scooters.
Paulnobodyimportant
Re: Aldi Bargin
Postby kennystag » Fri Feb 24, 2017 9:00 am
Yep I also got a another set of digital calliper from Aldi, set number 3, I just cart resist buying them. I am always leaving the bloody things switched on and the batteries are flat when I go to use them, so I have a couple packets of batteries from pound land.
Stag
:D
kennystag
Re: Aldi Bargin
Postby soulfecker » Fri Feb 24, 2017 1:12 pm
I don't know about the aldi ones, but I had a tap and Die set from Lidl, that includes M7.
Paul
soulfecker
Re: Aldi Bargin
Postby Knowledge » Fri Feb 24, 2017 1:52 pm
M7 eh? We all like a Brucie-bonus
Re: Aldi Bargin
Postby bike grim » Sat Feb 25, 2017 8:51 am
I got a tap and die set form Aldi a couple of years ago with M7. They have had quite a bit if use and still look brand new. The set also included a spark plug tap as well.
Re: Aldi Bargin
Postby Toddy » Sat Feb 25, 2017 10:38 am
bike grim wrote:I got a tap and die set form Aldi a couple of years ago with M7. They have had quite a bit if use and still look brand new. The set also included a spark plug tap as well.
Nice one, wat size tap is the spark plug one Gareth ?
Re: Aldi Bargin
Postby bike grim » Sun Feb 26, 2017 3:13 pm
Can't remember I'll check later
Re: Aldi Bargin
Postby P D: SC Chester » Sun Feb 26, 2017 8:52 pm
Tips welcomed.
Cheers WT. I do have the bible, but was wondering what I was doing wrong, as I couldn't get a reading from the solder inserted. Guess my squish must be well out. But I suppose it's better than it being too near the head?
As mine is too low, how would I solve this, my gaskets are only slim so nothing to be had there.
P D: SC Chester
Re: Aldi Bargin
Postby Warkton Tornado No.1 » Sun Feb 26, 2017 11:04 pm
To get the solder to give a reading, try twisting a loop up (into a spiral) & re-insert to test your squish.
As for head gaskets, personally I won’t use them, but it’s a matter of preference that some would disagree with...
Re: Aldi Bargin
Postby rossclark » Mon Feb 27, 2017 1:05 am
Get some 3mm solder off fleabay, if you don't get a reading with that then you're well out.
Re: Aldi Bargin
Postby corrado » Wed Mar 01, 2017 11:13 am
My local Aldi had TS1 kits for £99.99 so I bought all the ones they had.
Ooops, sorry wrong month, it's only March 1st, not April.
corrado
Users browsing this forum: No registered users and 166 guests
