help what carb can i use
Postby tottn15 » Thu Feb 23, 2017 4:28 pm
Hi i have a lui that has a 75cc kit, cento gear box and a vaga carb ,but the carb is worn ,can anyone tell which replacement carb i should get as a replacement any advise would be great
tottn15
Re: help what carb can i use
Postby Storkfoot » Thu Feb 23, 2017 6:03 pm
I know it sounds obvious but have you looked for an SH1/20 Vega carb? They are different to the standard SH1/20 because of the flip choke but they do come up for sale reasonably often and you can still source the flip choke from Dell'orto UK (they are often missing the flip choke).
Postby tottn15 » Fri Feb 24, 2017 10:22 am
I have brought 2 and both were worn ,this is why i am asking if there is a carb that i can use to replace the best one i have .thanks for your reply any way
tottn15
Postby Wack » Fri Feb 24, 2017 8:19 pm
Have a look through these,there may be something that would fit your manifold and remember bigger isn't always better.I use a stepped rubber to mount a PHBL 25 on the 20 mm manifold. http://www.dellorto.co.uk/product-categ ... 5-to-21mm/
Return to Carburettors
