hullygully wrote:Hi peeps, you cant just blame an exhaust for heat build up, other things to consider is your timing, carb (plug chops), cold/hot running plug, cylinder head squish, hot / cold day, enough air getting to your barrel / head, oil ratio, grade of fuel, two-up with full camping gear, I could go on.... ..........![]()
mind you I've just taken my bullet proof 42mm Ancillotti off my cast Gori 200 (took me to German Euro & back) & replaced it with a BGM 48mm Clubman, so watch this space![]()
